2006 Altima 2.5 S Hard Starting (ECM Issue?)
My girlfriend is having problems with her Altima. It will stall sometimes while driving and it is often hard starting. My imediate thought was the Idle Air Control Motor, however after having a technician diagnose to the problem, he told us that the ECM is shot. He stated that the crankshaft position sensor shorted out, inturn frying the ECM. The codes that he read were: the Idle Air Control Motor and the Crankshaft Postion Sensor. He is a reputable mechanic, however I want to check the forum to make sure this makes sense, before replacing the EMC. It seems like a car this new (though 55k miles) should not be needing a new ECM. Any thoughts?
I doubt the ecm is bad. Replace the crank sensor with the updated part from Nissan.
Thanks for the advice. Though I hear the Crank Sensor is easy to change, I am not sure where it is located, I may have to take it in for the repair. What are your thoughts on the IAC motor codes? Does this need to be replaced as well? Thanks again...
I'm actually gonna do the crankshaft sensor on my own, can you tell me where its located or help me find a diagram. I did the speed sensor without a problem is the crankshaft sensor in the same general area?
part should be arriving in a few days. |
part arrived but still can't find it. I'll keep looking tomorrow and check if anyone else has posted.
thanks |
On the back side of the engine between the fire wall near where the trans bolts to the engine.You should be able to see it from underneath.
if i'm standing on the driverside of the car reaching into where i found the speed sensor
am i in the right area? do i go deeper? |
Got it. all replaced and started, now we'll see if the check engine light no longer comes on.
2004 Nissan altima 2.5 liter Crankshaft Position Sensor - FixYa very good instructions for me, really helped out |
