2005 parking brake adjustment
Anyone know how to adjust the nut that is on the parking brake pedal on 2005 pathy? appreciate the detailed info....my car no longer hold with pedal pushed to floor
The adjustment for the parking brake is at the rear brakes. The R51 uses a "hat style" system where the inside hub of the rear brake rotor is also the drum for the rear parking brake shoes, which use a star adjuster like a rear drum brake setup typically does. There's an access window in the hub of the rear brake rotor so you can adjust it.
But what is the deal with the adjustment nut on the pedal? I engage it slightly, loosen the night, disengage the pedal, then tighten it back down?
Here's what the ALLDATA states in regards to parking brake adjustment:
: 2005 Nissan-Datsun Truck Pathfinder 4WD V6-4.0L (VQ40) Vehicle Level Brakes and Traction Control Parking Brake System Parking Brake Control Adjustments Adjustments ADJUSTMENT
2005, adjustment, brake, parking |
