04 max anifreeze slow leak
Any idea where its comming from? when car drives fast temp gage is fine at idol engine starts getting hot. and dose this have anything to do with no heat at idle in wintertime? Kelly
Take time to play, its the secret of perpetual youth. :o |
Can you see the leak? or from where is coming from, what part of the engine? front, back, middle, left front, etc.?
Or you are assuming there is a leak because the engine is overheating?
when u run a/c some water drips if that what u are refering to???
2002 Maxima GLE Silver on Black | Berk Intake w/AEM Dryflow | Clear Sidemarker Lights w/PIAA L.E.D|PIAA L.E.D Courtesy and Licence Plate Lights|PIAA White Fogs |Fibre Customs EyeLids | 5% Limo Tint | Brembo Blanks and Hawk HPS Pads |Ebay FSTB|CATTMAN RSB| NWP VIAS Block plate and NWS Spacers| OEM Spoiler | 07 350 z rims on 235/45/18 Goodyear Eagle GT tires| Megan Racing OE-RS Catback | in training |
I am assuming its a slow leak because I smell burning antifreeze and I have to add antifreeze every 2-3 months, when the car overheats its usually a sign the anti freeze it pretty empty. as far as where its comming from were not sure because it seems to burn off before it hits the driveway.
could be your thermastat, turn the car on and inspect all around the radiator and your coolant tank. the tank itself might have a leak.
From what you have told us you have a bad air pocket traped within the coolant system. Thats the reasion for the no heat and the engine trying to overheat. Take your vehicle to a good tech with some nissan background an he will know how to get the air out.
anifreeze, leak, max, slow |
