99 Maxima 1320 code problem Forums > > 99 Maxima 1320 code problem 99 Maxima 1320 code problem
Old 06-13-2008, 07:34 AM
sps1177
Default 99 Maxima 1320 code problem
Chk. Engine light came on and code 1320 found. Replaced plugs and ALL
ignition coils. Erased code. Light back on with same 1320 code. I chk. wiring and all seem in order, but code persist. Any suggestions? Thanks.
Old 06-13-2008, 08:17 AM
sergey85's Avatar
sergey85 sergey85 is offline
p1320 an ingnition signal
2002 Maxima GLE Silver on Black
| Berk Intake w/AEM Dryflow | Clear Sidemarker Lights w/PIAA L.E.D|PIAA L.E.D Courtesy and Licence Plate Lights|PIAA White Fogs |Fibre Customs EyeLids | 5% Limo Tint | Brembo Blanks and Hawk HPS Pads |Ebay FSTB|CATTMAN RSB| NWP VIAS Block plate and NWS Spacers| OEM Spoiler | 07 350 z rims on 235/45/18 Goodyear Eagle GT tires| Megan Racing OE-RS Catback |
in training
SHOW YOUR SUPPORT: Subscribe or Donate
Old 06-13-2008, 08:20 AM
sergey85's Avatar
what kind of plugs did u use, im also thinking it might be a problem with the coils as well wait till a specialist replies. does it sputter or drive differently?
Old 06-13-2008, 08:51 AM
sps1177
Used NGK plugs with OEM coils. Eng. has slight miss on occassion, and SES light comes back on. Connections seem to be tight. I can erase the 1320 code, but it returns within the day. Thanks.
Old 06-13-2008, 09:06 AM
Did you use NEW factory coils? The code and symptom points to a bad ignition coil.
Old 06-13-2008, 09:14 AM
sps1177
Yes. New coils. Can the coils be tested easily?
Old 06-13-2008, 09:30 AM
Not really since the problem is intermittent. The service manual shows you how to measure the coils, but usually all coils are with specs
Old 06-13-2008, 10:16 AM
sergey85's Avatar
make sure that the coils are secured right and the screwes are not damaged. yeh its gonna be hard pin pointing the exact coil expesially if it comes and goes.
Old 06-13-2008, 10:18 AM
sergey85's Avatar
got this off of the org site to test your coils
How to verify if your coil packs work!
Engine worked with: 1996 maxima
Requires: An ohmmeter (cheap purchase at radio shack....)
Conditions: Make sure your engine is cold, or it'll be hot on your hands
you have 6 Ignition coil packs. 3 up front and 3 near your firewall. (when asking for new ones, they are referred to as L and R)
3 are hidden behind the plastic piece on your engine that says NISSAN... simply remove the bolts and remove the plastic piece.
once removed, you should see 3 coil packs. un plug and test them one at a time.
I won't go into how to remove them since it should be fairly obvious Simply remove both bolts (do one coil pack at a time...) and pull the coil pack out. i had one where it was very hard to get out... so you may have to pull hard...
Once out, look at the area where you removed the electrical plug. You should see a "+" on the back end of the electrical plug. There should also be the letter "B"....
the spot where you see the positive symbol, means that's prong number one on the electrical connector.
To test:
Turn on your ohmmeter and place the positive wire on the 1st prong in the electrical plug of the coil pack. The negative wire should be touching the middle prong. Verification of the ohmmeter at this time should say "0" aka infinite... if it's anything else, the pack should be changed. Next test: reverse the wires... positive on the middle prong and negative on the 1st prong.... on a new coil pack, it should give a value of approximately 1.3-1.7 mega ohms. If any of the readings are off, replace the coil pack.
Note: Firewall coil packs are extremely easy to find, simply look in the cracks of the intake header. you'll see 3 similar looking coil packs to the front ones. The exception with these is that they are longer and look a slight bit different. removal is the same process as the front coil packs. Simply pay special attention to not dropping the screws in the intake area... it'll be hard to get out
to test: follow the front coil pack testing method. Look for the Positive symbol, this is your first prong... and go from there
Old 06-15-2008, 10:27 AM
sps1177
Thanks for the through detai,ls concerning testing the coils. I will test after I acquire an ohm meter. Thanks again. I appreciate your effort.
Old 06-15-2008, 12:10 PM
sergey85's Avatar
yeh no problem post with your results good luck
Old 06-26-2008, 08:10 AM
sps1177
Tested coils per your post and found #5 defective, replaced, and erased 1320 code. Driving for past 2 wks. and no problem, or light. Note: careful when purchasing coil. Take coil to store and compare the connection depth. Some non-oem coils connection lip is 1/4" deeper than original. It will connect, but not snap into place. This may cause connection to loosen.
Thanks again for your expert advise. It saved me a bundle!
Old 06-26-2008, 12:08 PM
sergey85's Avatar
awsome bro
Old 09-19-2009, 12:09 PM
seanmc
Default disconnecting the coil pack
How do you disconnect the electrical connection to the coil pack. Is there a latch to it or does it simply pull off?
Old 09-20-2009, 04:40 AM
desert_fox's Avatar
desert_fox desert_fox is offline
You stick the pointed edge of a screwdriver on the lever part and push push push until it pops off.
1320, code, maxima, problem
