All Models, All Years 2009 350Z 2009 Altima 2009 Altima Coupe 2009 Altima Hybrid 2009 Armada 2009 Frontier Crew 2009 Frontier King 2009 GT-R 2009 Maxima 2009 Murano 2009 Pathfinder 2009 Quest 2009 Sentra 2009 Sentra SE-R 2009 Rogue 2009 Titan Crew 2009 Titan King 2009 Xterra 2009 Versa
Do-It-Yourself Cost Estimator Maintenance Owners Manuals Recalls/Campaigns Service Bulletins Service Manuals MyNissan
Auto Parts Car Cover Clear Cargo Mats Clear Mats Hexomats Hexomat Cargo Sunshades
Go Back   Nissanhelp.com > Models > Maxima
  #1 (permalink)
Old 03-06-2008, 11:55 PM
bnc211's Avatar
Newbie
2003 Nissan Maxima SE
Default 2003 Maxima SE
About 6 months ago I started hearing a metalic rattling noise from the undercarriage. It is an internittent noise but occurs most frequently between 30 and 40 miles an hour or at low RPMs. I took it to the dealership and they said it was the heat shield. They removed the heat shield and said the problem was fixed. Unfortunately, 3 months later the noise is still there and is ocurring more often. Has anyone else experienced this problem? Any suggestions? THX
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
  #2 (permalink)
Old 03-07-2008, 12:27 AM
gotendbz1's Avatar
Newbie
2003 maxima
if you go to the muffler and move it up and down, do you hear the noise? if so it might be the insulator that is connected to the exhaust pipe has came loose. it is welded on. pu tit on a lift and u can see.
  #3 (permalink)
Old 08-02-2008, 05:11 AM
3.0bnm's Avatar
Newbie
2003 SE Titanium Edtion
Default 2003 Nissan Maxima SE Rattling Sound / Noise
Yes, i have the same problem with my 2003 Maxima SE manual tranny. My mechanic says its the fuel i put in, but i only use the highest grade octane and only name brand gasoline, like Shell 91 oct. and sunoco 94 oct. so i dont belive this is the cause.
The rattling sound im getting only happens when the car is in gear and between aprox 1700 rpm and 2000 rpm. The rattling gets louder when the car has more load, like when im going up a slight hill and stuff like that. At the begining my mechanic also told me it was the heat shields and so on, but im sure its not ( i even removed the heat shields ). I also noticed that when i shut the car off, again this rattling occurs briefly.
Could this problem be caused by the Cam. Position Sensor. could this be screwing up the timing or something. Someone out there please help.
Trackbacks are On
Pingbacks are On
Refbacks are On
THINGS YOU CAN DO ALSO ON NISSANHELP.COM NISSANHELP.COM STORE
Privacy Statement - Advertise with Us - Terms of Use Copyright 1999-2008 Nissanhelp.com
ChevyMalibu.net - HelpForCars.net - Infinitihelp.com - Lexushelp.com - Nissanhelp.com - Scionbeat.com - WikiAutoRepair.com
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.1.0
