#16
i also have a 2001 maxima and the abs/slip/tsc lights just came on. If restarted they went out, however, now they are on all the time. Could it be an abs sensor
#17
how do i replace the abs sensor in the front
#18
I have the same issue. Tried extracting the codes with the flashing lights but cannot get it to work. Not sure what to try next.
#19
ground?
I'm having the same problem. I can't seem to get the lights to flash out the code. Maybe I'm not "grounding" pin 9 properly. What exactly is the best way to ground a pin? I thought it was as easy as using a paper clip, but that doesn't seem to be working for me...
#20
Hello my problem is a little different but similar, I got "Check Engine" + SLIP + tsc lights, all at once. But not ABS. They all come on together when I am driving for a few minutes. No other perceived problems yet... Then today the SLIP and tsc went off at some point, but Check Engine stayed on... I hate this type of problem. Any ideas on this one?
#21
The TCS light in my Nissan Maxima 2001 is on & i feel the car slipping
#22
I have the same problem with my 2006 Maxima except that I also have no A/C, dash controls, fan, and my brake light is also on. My speedo doesn't work and neither does my fuel gauge. Would all of this be because of a bad sensor? I had new tires, brakes, and an inner tie rod replaced last week.
2001, abs or tcs or slip, maxima, problem |
