2014 Setting reset on power off and no obd power
I am looking to see where the obdII port gets power as I think that is also the power that stores the Mileage and settings of the display under the speedo. The car runs great but the problem is that the settings are not staying and the OBDII port has no power. I tried my scanner on an Xterra and it works fine. Does anyone know what fuse or fuses I should look at? I thought I looked at all of them in both the Engine and under the dash.
Please help!!!! Thanks |
Persistence pays off. So 24 hours later I have found it. There is a fuse that is covered by a big plastic clip. Under that clip holds the 10 amp fuse. After replacing the fuse the OBDII works as well as it keeps the odometer readings!!
I do not know how to post photos, but I do have them if anyone else has this issue. Thanks |
2014, obd, power, reset, setting |
