2011 Maxima passenger side window no longer allows automatic feature
The passenger side window no longer allows the automatic feature to allow the window to go up or down automatically when I pull up or push down like the driver side window does/like it used to. Any suggestions?
Try initialize the window motor.
1. Operate power window switch to fully open the window. (This operation is unnecessary if the window is already fully open) 2. Close the window. 3. Continue pulling the power window switch UP (AUTO-UP operation). Even after glass stops at fully closed position, keep pulling the switch for 4 seconds or more. If the problem persist, you may have a problem with the window motor or switch.
RE: 2011 Maxima passenger side window no longer allows automatic feature
Thank you! I asked around before posting on here and the motor was also a suggestion. I dont believe it can be the motor cause neither switch works for the automatic feature, the one on driver side nor passenger side. I will try your suggestion, hopefully it works :)
Thanks, Nisssan Tech! |
Works for 2012 Altima too
1995 Maxima SE (313,000+ miles 10/2012) 1997 Maxima (193,000 miles - bought from daughter when she traded for a Hyundai Elantra Coupe) 2002 Altima (daughter - totaled 12/2011 with 210,000 miles) 2012 Altima (daughter - replaced 2002 with 8 miles, now with almost 30,000 miles) |
That worked! thanks again! My cigarette lighter 12 volt without any ideas on fixing that?
Nissan Master Switch
Thank you for this info, saved one of my customers the headache
2011, automatic, feature, longer, maxima, passenger, side, window |
