All Models, All Years 2013 370Z Coupe 2013 370Z NISMO 2013 370Z Roadster 2013 Altima Coupe 2013 Altima Sedan 2013 Armada 2013 Cube 2013 Frontier Crew 2013 Frontier King 2013 GT-R 2013 Juke 2013 Leaf 2013 Maxima 2013 Murano 2013 CrossCabriolet
2012 NV 2013 NV200 2013 Pathfinder 2013 Quest 2013 Rogue 2013 Sentra 2012 Sentra SE-R 2013 Titan Crew 2013 Titan King 2013 Versa Sedan 2012 Versa Hatchback 2013 Xterra Concept Models 2014 GT-R 2014 Pathfinder Hybrid 2014 Versa Note
Classifieds - For Sale Classifieds - Wanted To Buy Classifieds - Mechanic Wanted Classifieds - Auto Services Search Auto Parts Ultimate Reflector Auto Sun Shades Custom Fit Car Covers Auto Snow Shades Berber Auto Mats Coco Auto Mats Designer Auto Mats Diamond Plate Auto Mats Fashion Auto Mats Flexomats Auto Mats Hexomats Auto Mats
Forums Nissan Models Maxima Maxima Head Light Removal to change a bulb
  #1 (permalink)
Old 04-02-2007, 02:51 AM
umelen's Avatar
2005 Maxima 3.5 SE
Default Maxima Head Light Removal to change a bulb
Hi,
Any body knows how to safely remove a headlight assembly, I took the two bolts off, and still there was something holding it, some pins probably since I did not know where they were I did not pry, your help will b appreciated
  #2 (permalink)
Old 04-02-2007, 08:43 PM
1. Remove the front fascia. (See First Figure)
1. Remove radiator grille. 2. Remove screws on each side of bottom of fascia that attach fascia to bottom of fender protector. Partially
remove fender protector.
3. Remove engine underside covers.
4. Remove engine front undercover.
2. Ensure lighting switch is OFF.
3. Disconnect the negative battery cable.
4. Remove the combination lamp mounting bolts. (See Second Figure)
5. Pull the combination lamp up and toward the front of the vehicle,
disconnect connector and remove from vehicle.
Maxima Head Light Removal to change a bulb-figure002.gif   Maxima Head Light Removal to change a bulb-figure001.gif
CarZone Auto Repair - Nissan Service Center - Van Nuys CA
Nissan OBD-II Trouble Codes
Show your support to our forums and get unlimited access to the knowledge base files: Subscribe
  #3 (permalink)
Old 04-06-2007, 07:12 AM
umelen's Avatar
2005 Maxima 3.5 SE
THank you very much, appreciate your help, I did not think it would be this service unfriendly
Again thanks
  #4 (permalink)
Old 04-08-2007, 04:19 PM
surfsalterpath's Avatar
Default replace a maxima headlight bulb
do you have to go to all this trouble to replace the headlight bulb?
I just replaced mine and all I did was
pinch the sides of the black plug together to release the
plug from the bulb. Pull the rubber boot back and unclip the bulb and replace.
Just make sure you do not touch the bulb itself.
  #5 (permalink)
Old 08-17-2007, 07:30 AM
jligon1@mac.com's Avatar
2004 MAXIMA 3.5SE
I agree this is service unfriendly.
What is the fascia? Is it what cars have now that they no longer have bumpers?
  #6 (permalink)
Old 10-19-2007, 02:29 PM
2011 Rogue
For the 2005 maxima you can remove a couple screws from the fender liner and gain access to the bulb by turning the steering wheel all the way depending on which side you are working on. Pull the fender liner back and you can get to the cap for the bulb. It is much easier this way.
The 1999 maxima is much easier. You can open the hood and gain access from the back of the headlight.
  #7 (permalink)
Old 07-17-2008, 03:35 PM
mbednorzjr's Avatar
2002 Nissan Altima
Thanks for the pics, i need to replace the complete headlight housing on both sides. This is very helpful
  #8 (permalink)
Old 08-17-2008, 12:21 PM
oakwood79's Avatar
Thumbs up Thank you!!!!
I took mpe235 advice and went through the fender well and it worked like a charm. I had the bulb replaced in no time. I would definitely suggest this way than rather remove the radiator grille or bumper as some told me to do. Thanks again.
  #9 (permalink)
Old 11-10-2008, 04:43 AM
hwmason's Avatar
I gained access to my driver's side combination halogen bulb (L-shaped plastic / bulb unit) by removing the air cleaner housing (one bolt, then pull up out of rubber grommet mounts). I then removed the large plastic cover by turning counterclockwise to unlock. This exposed the bulb. I unplugged the electrical connector. At this point I couldn't figure out how to remove the bulb. Some on the web say rotate the bulb, but there is something preventing it from turning. Anyone know how to remove the bulb?
  #10 (permalink)
Old 11-29-2008, 10:31 AM
joe carps's Avatar
I have read some information from your site in regards to changing a headlight bulb on a 2004 maxima[passenger side]. Which way is the easiest.
  #11 (permalink)
Old 02-12-2009, 03:08 PM
xxcubanpapixx's Avatar
That was really helpful ! thank you for the pictures of how to take the bumper off and replace the headlights
  #12 (permalink)
Old 02-25-2009, 11:33 AM
04 massacre's Avatar
I see how to replace the bulb, but is anybody else getting quotes for $130 for just the bulb itself? There has to be something less expensive
  #13 (permalink)
Old 03-02-2009, 12:45 PM
shonnhunter's Avatar
I was getting quotes from the 125 - 170s for just one damn bulb.
  #14 (permalink)
Old 03-02-2009, 01:09 PM
sergey85's Avatar
try ebay or maxima.org in the vendor section those projector bulbs and xeon bulbs can be expensive.
2002 Maxima GLE Silver on Black
| Berk Intake w/AEM Dryflow | Clear Sidemarker Lights w/PIAA L.E.D|PIAA L.E.D Courtesy and Licence Plate Lights|PIAA White Fogs |Fibre Customs EyeLids | 5% Limo Tint | Brembo Blanks and Hawk HPS Pads |Ebay FSTB|CATTMAN RSB| NWP VIAS Block plate and NWS Spacers| OEM Spoiler | 07 350 z rims on 235/45/18 Goodyear Eagle GT tires| Megan Racing OE-RS Catback |
in training
SHOW YOUR SUPPORT: Subscribe or Donate
  #15 (permalink)
Old 03-02-2009, 04:59 PM
2011 Rogue
I haven't tried it but I have been told a 9006 bulb will fit. Those are around $20.00.
  #16 (permalink)
Old 03-05-2009, 02:05 PM
Yup, just confirmed it. The 9006 bulb works like a charm, there is only a slight difference in the brightness of the bulb from the factory ones. If you purchase a 9006 bulb that burns at around 5000k or so then they will be pretty much the same but way less expensive than whats recommended
  #17 (permalink)
Old 03-06-2009, 05:11 PM
coolswitch's Avatar
1989 Maxima
anyone have an idea how to remove the whole headlight assembly for a 87-89 maxima? I need to repaint the reflector.
thanks
  #18 (permalink)
Old 09-23-2009, 04:08 PM
wlk239's Avatar
I had to replace both of my headlight assembly's on my 2004 Maxima thanks to a previous owners 'after market' wiring & bulb replacement so thanks for all of the info about removal of the headlight assembly. I have tried it both ways (taking the wheels off & taking the front fascia off) and I think taking off the front fascia is the easiest!
PROBLEM: After installing new headlight assembly's, the passenger side high beam light does not work, any suggesstions? I have checked all fuses and wiring and cannot find any obvious signs of problems. Also is there any way to adjust the beam direction/height on my new lights?
  #19 (permalink)
Old 11-17-2009, 11:12 AM
robo_geek's Avatar
2007 Maxima
Default on the 2007
the shop manual says to take off the front bumper (fascia) but you can change the driver side by just taking part of air intake off, and the passenger side can be done (with some difficulty) by unsnapping and flxing the inner fender liner on that side, and reaching in from there.
Not unlike unhooking a bra by reaching in up under the rear of a blouse
  #20 (permalink)
Old 11-27-2009, 10:31 AM
kdog88's Avatar
I've owned 10 auto's in my life time and always been able to replace a headlamps, but never in my life seen a messed up design like the one on the 2005 maxima. its ridiculous to have to pay that amount or go to that much trouble just to change a bulb!
bulb, change, head, light, maxima, removal
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://x.nissanhelp.com/forums/maxima/2357-maxima-head-light-removal-change-bulb.html
Posted By For Type Date
2006 Maxima Headlight Replacement This thread Refback 04-25-2010 08:41 AM
Nissan Repair - Auto Repair - Home/Garden This thread Refback 03-01-2010 10:35 PM
The Zoo Clan :: This thread Refback 11-29-2007 02:29 AM
Untitled document This thread Refback 11-25-2007 02:27 PM
Untitled document This thread Refback 11-25-2007 01:55 PM
The Zoo Clan :: This thread Refback 11-25-2007 01:32 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.0
