All Models, All Years 2017 Armada 2016 Altima Sedan 2016 Frontier 2016 JUKE 2016 LEAF 2016 Maxima 2016 Murano 2016 NV 2016 Rogue 2016 Sentra 2016 Titan XD 2016 Versa Note 2016 Versa Sedan 2016 Z Concept Models
Forums > > 97 Maxima starting problem w/ bad crank sensor (ref)
  #16
Old 06-27-2016, 10:55 PM
OilCanObserver's Avatar
OilCanObserver OilCanObserver is offline
1995 Maxima
if the hard start continue to persist, suggest you do the following:
1. make sure there's no intermittent disconnection (breaks) of wiring between the ckps (ref) & the sub-connector on top of the engine block. replacing these wiring could be difficult because it's routed in tight spot & the possibility of getting caught by the ps system.
2.code 1335 could also be caused by slow speed of the starter motor due to insufficient current flow between the battery & the starter motor body caused by poor ground. use 3 #10 awg (of equal length & as short as possible) in parallel. use # 10 O-ring terminals for each, & connect to the negative terminal of the battery, bunch the other ends with #6 O-ring & connect it to the most accessible mounting bolt of the transmission body to the engine block. make sure both sides of the washer, the mating surfaces of the bolt head with the washer & the transmission body with the washer shiny clean. (you may also connect to one of the starter mounting bolts & make sure all mating surfaces are shiny clean as previously described.)
the main negative cable is bolted to the engine block. imo, the grounding connection from the engine block to the transmission body, is through the mounting bolt (threaded to the engine block), through the mating surfaces with the bolt head with the washer, & through the mating surfaces of the washer & the transmission body. if there's oxidation (corrosion) to those (mating surfaces) poor ground could result. the mounting ear holes of the transmission body for the mounting bolts are quite big. imo, there may not be physical contact with the mounting bolt shank & transmission body, hence no electrical connection. (alternatively, you don't need to add ground wires as long as you can make all those mating surfaces of the washers, bolt head & transmission body shiny cleaned, but it could be a pita.)
  #17
Old 08-27-2016, 01:24 PM
Hotchymotchy's Avatar
Hotchymotchy Hotchymotchy is offline
1995 Maxima
Problem solved. Shredded p/s belt damaged Cranck Sensor harness so Had it replaced all the way back to the ECM. Starts and runs great again. Shop said the 2 wires from the CPS were roached all the way back to the connector at the computer.
  #18
Old 09-10-2016, 09:27 PM
1995 Maxima
Turns out that replacing the 2 crank sensor wires all the back to the Engine Control Module fixed the problem. Harness must have gotten damaged and shorted when the p/s belt came apart.
  #19
Old 12-04-2017, 10:22 PM
logansinc's Avatar
logansinc logansinc is offline
1997 Frontier Crew Cab
2010 Titan Crew Cab
Default This girl has been voted as the sexiest woman in the world
Wow, she is one of the most beautiful girls I have seen
Miranda Kerr is beautiful - YouTube
bad, crank, maxima, problem, ref, sensor, starting, w or
Privacy Statement - Advertise with Us - Terms of Use - Copyright 1999-2017 Nissanhelp.com
Copyright ©2000 - 2017, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO v2.0.0 Beta 2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
