All Models, All Years 2013 370Z Coupe 2013 370Z NISMO 2013 370Z Roadster 2013 Altima Coupe 2013 Altima Sedan 2013 Armada 2013 Cube 2013 Frontier Crew 2013 Frontier King 2013 GT-R 2013 Juke 2013 Leaf 2013 Maxima 2013 Murano 2013 CrossCabriolet
2012 NV 2013 NV200 2013 Pathfinder 2013 Quest 2013 Rogue 2013 Sentra 2012 Sentra SE-R 2013 Titan Crew 2013 Titan King 2013 Versa Sedan 2013 Xterra Concept Models 2014 370Z Coupe Nismo 2014 GT-R 2014 Pathfinder Hybrid 2014 Versa Note 2014 Versa Sedan
Classifieds - For Sale Classifieds - Wanted To Buy Classifieds - Mechanic Wanted Classifieds - Auto Services Search Auto Parts Ultimate Reflector Auto Sun Shades Custom Fit Car Covers Auto Snow Shades Berber Auto Mats Coco Auto Mats Designer Auto Mats Diamond Plate Auto Mats Fashion Auto Mats Flexomats Auto Mats Hexomats Auto Mats
Forums Nissan Models Maxima Cigarette lighters don't work
  #1 (permalink)
Old 01-23-2012, 06:37 PM
Rheadley's Avatar
Default Cigarette lighters don't work
Help - both cigarette lighters don't work and the named fuse is fine. No fuse appears blown in either fuse panel. What to check next? Both worked recently.
  #2 (permalink)
Old 01-23-2012, 06:59 PM
If the fuses are OK then the next step is to check the wire to the socket. You have to remove the sockets and check if there is power to the socket connector. I have attached and image of the wire sockets wire diagram that I hope it helps you find the problem.
CarZone Auto Repair - Nissan Service Center - Van Nuys CA
Nissan OBD-II Trouble Codes
Show your support to our forums and get unlimited access to the knowledge base files: Subscribe
  #3 (permalink)
Old 02-12-2012, 07:06 AM
Vals2010's Avatar
1999 Altima
2005 GTR
Default Nissan
Hello!
Thank you for the diagram becasue I think what is wrong with it now, is the relay. I found the fuse that goes to the lighter to be blown. I didn't had a fuse at the time so I just wrapped a "tiny" which I thought it was(not) a tiny wire around the fuse and stock it back in there. I was gone replace it eventually but it was just for the time being. Then my friend gets me an idea to change my deck, so I went bought the wiring harness and since I already had a CD player ready to install I went ahead and took out the trim to get to the stock CD player. I had forgotten all about what I did with the fuse and while taking of the trim I accidentally short circuited the cigarette lighter. Well after I hooked up the CD player I noticed that it doesn't work. So then I checked the fuse and it was fine. So I thought that the new deck is broke, but then I reconnected the stock Cd player and it wouldn't work either. Then I checked the cigaret lighter for power and it was not putting out any power either. So I went and got a new fuse for the cigarette lighter and it didn't solve the problem. The fuse stays good but neither the CD player or the Lighter works now. So I said dam and wired the deck to the light power wire so now the CD player works only when the lights are turned on. Then I noticed other problem that new CD player works fine but doesn't produce any sound. That was weird. I know what I did wrong, but how do I fix it?
  #4 (permalink)
Old 02-12-2012, 12:54 PM
2011 Rogue
You probably melted the harness somewhere when you put the piece of wire in the fuse box. The fuses are there for a reason.
  #5 (permalink)
Old 02-13-2012, 06:55 AM
Vals2010's Avatar
1999 Altima
2005 GTR
Default Nissan
According to an electric diagram it must be the relay. It really gone suck if it's not, but if it is then I would have to take off the fuse panel and check there? I think that if it was the fuse box wire harness then only the cigarette lighter wouldn't work, but both went out the CD player and cig. lighter outlet. On the diagram it shows how the current goes through a double relay then the fuse and then it splits and one goes to the cig. lighter outlet as other goes somewhere else? The diagram is a bit confusing tho.
  #6 (permalink)
Old 08-14-2012, 05:06 AM
joekidng's Avatar
2004 Quest
2006 370Z Coupe
I have the same problem with my 2004 Quest cigarette lighters just quit.
I checked all fuses in the panel by my left knee all were good. Not too sure what to do or change now. Any Ideas. The only cigarette lighter that works now is the one at the very back of the van. All the other 3 are dead.
cigarette, fuse, lighters, work
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.0
