Forums > > No heat, even during acceleration
Old 12-07-2010, 11:34 AM
OMDB
Default No heat, even during acceleration
Like many here, I have no heat (awful time to notice this.) Even when accelerating I have nothing. I'll set it to 85 and it'll blow hard but the air isn't warm. If I put the fan down I can tel it's lukewarmish, but so close to air temp that, when blowing hard, it isn't noticeable.
I had the radiator replaced out of state this past summer. I assume it may be connected. The car's engine temp is perfect and right where expected.
Everything I've read, though, says that if there's air in the radiator I should still get heat when accelerating. This makes no difference. Stuck thermostat? Costly?
Old 12-07-2010, 07:56 PM
nissan master tech's Avatar
nissan master tech nissan master tech is offline
1998 Pathfinder
2001 maxima 20th aninvers
try flushing the heater core
Old 12-08-2010, 04:39 AM
desert_fox's Avatar
desert_fox desert_fox is offline
...or replacing the thermostat...
Old 12-08-2010, 06:55 AM
bobflood bobflood is offline
1997 Maxima
1997 Maxima
If your engine temp is correct, then the thermostat or air in system are probably not the issue. Once the engine warms up, feel the heater hoses to see if they are warm/hot. If both are hot, then coolant is passing freely; if only one is hot, then coolant is restricted and you would have to flush/replace the heater core. If both are hot, coolant is passing freely and more likely your air mix door or intake air door are the issue. They are controlled by the auto air computer; but most likely issue is mechanical in that the motor to one of them has failed so no warm air is mixing, or cold intake air is not being reduced.
1997 Maxima SE, 5 speed, dark green with tan leather, 235K+ miles and still going strong.
Old 12-21-2010, 04:24 AM
DCARLTON DCARLTON is offline
1995 Maxima
1997 Maxima GLE
I disagree. My daughters 97 Max temperature was right where it was supposed to be, just under the half way point and was fine until Winter when it turned cold. She had bought this car used in the Summer. It wouldn't blow any heat to amount to anything.
Thinking that maybe it was a thermostat, I decided to replace it. Took the old one out and was surprised to find, no thermostat was present at all in the housing!
Replaced thermostat, re-filled and began getting heat.
A faulty thermostat in open position, or in my case, none, will allow engine to warm but not get warm enough to blow HOT air.
Edit; Also, on an Altima (my other daughter has that one), the engine temp is fine but get a little air in the system and it will only blow hot when moving, not sitting still.
Air doesn't transfer heat as well as water does but since you say you don't get heat when moving, I would suspect thermostat.
1995 Maxima SE (313,000+ miles 10/2012)
1997 Maxima (193,000 miles - bought from daughter when she traded for a Hyundai Elantra Coupe)
2002 Altima (daughter - totaled 12/2011 with 210,000 miles)
2012 Altima (daughter - replaced 2002 with 8 miles, now with almost 30,000 miles)
Old 12-21-2010, 04:54 AM
1997 Maxima
1997 Maxima
I still think that one of the mix doors is the more likely culprit, but a bad thermostat is also a posssibility, so give it a try.
dcarlton: How hard was it to replace the thermostat? The FSM makes it look easy, but I suspect there are things (a/c compressor?, alternator?) in the way.
Old 12-21-2010, 04:58 AM
1995 Maxima
1997 Maxima GLE
It's like everything else on that side of the engine, hard to get to but it's not real difficult. Anything on that side will try your patience! I just got through doing a water pump on my 95. You can remove more than necessary to get to the t-stat, or struggle through it and only remove what the FSM says.
The thermostat costs about $20 if my memory is correct and an easy fix if it works. It can't hurt especially if it's been a while since it was changed out or if it's never been changed an has mileage on it.
Old 12-21-2010, 05:19 AM
1997 Maxima
1997 Maxima
OMDB - Sounds like changing the thermostat is a middling hard DIY job (because of access to it) and the new thermostat plus gasket is about $30. However, that is bound to be easier/cheaper than troubleshooting/repairing the doors inside the dash. So, if the heater hoses are only warm with engine fully warmed up and heat on high, this is probably the best next step. However, if the heater hoses are both hot, that means that high temp water is circulating thru your heater core and the problem is more likely one of the air doors.
Old 12-22-2010, 08:01 AM
robo_geek
Trapped air can cause this.
You need to either have the system purged with a cooling system fill/purge device, or do the technique where you get the front end of the car like 3 feet in the air with the radiator cap off while adding coolant.
Three-feet in the air method:
Nissan Maxima Low Heater Output
This is a stupid design....why not add a simple bleeder screw?
Cooling system fill/purge tool:
UView 550000
Airlift Cooling System Leak Checker and Airlock Purge Tool Kit
UView 550000 Airlift Cooling System Leak Checker and Airlock Purge Tool Kit
acceleration, heat
