All Models, All Years 370Z Coupe 2010 370Z Roadster 2010 Altima Sedan 2010 Altima Coupe 2010 Altima Hybrid 2010 Armada Cube 2010 Frontier Crew 2010 Frontier King GT-R 2010 Maxima Murano 2010 Pathfinder Quest 2010 Sentra Sentra SE-R Rogue Titan Crew Titan King 2010 Xterra Versa
Do-It-Yourself Cost Estimator Maintenance Owners Manuals Recalls/Campaigns Service Bulletins Service Manuals MyNissan
Auto Parts Car Cover Clear Cargo Mats Clear Mats Hexomats Hexomat Cargo Sunshades
Go Back   Nissanhelp.com > Models > Maxima
  #1 (permalink)
Old 11-07-2009, 12:42 PM
Mycabert's Avatar
Newbie
Default Abs code 2001 nissan maxima se anniv ed.
Hello fellow Nissan friends. My ABS light went on and when I went to my mechanic and installed a diagnostic consult, the codes didn't appear on the consult. Is there anyone out there who knows the code so we can determine or pinpoint what the problem is causing the ABS lights to be on constantly? Without this code we cannot determine if it's the sensors (front or rear, left or right), or a harness defect, etc. Now when the light goes on, it automatically transforms to ordinary braking system. The ABS is disengaged. Help would be highly appreciated.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
  #2 (permalink)
Old 11-11-2009, 03:01 PM
When a ABS component goes bad (ABS sensor, control unit, pump, relay, etc) it triggers the ABS warning light and stores a code in the ABS control unit. Every component has a code, so when you read the code in the ABS control unit you know what component has failed.
The ABS is suppose to reset every time you turn the ignition switch OFF. Next time the ABS light is ON, you should drive to an independent shop or the dealer and have them read the code, when you get to the shop DO NOT TURN THE ENGINE OFF, if you do the code will be erase.
NEW - MPG Estimates - Share your MPG
Nissan OBD-II Trouble Codes Chart
Show your support to our forums: Subscribe or Donate
  #3 (permalink)
Old 11-11-2009, 05:34 PM
Mycabert's Avatar
Newbie
Thank you for responding...even when I shut the light off...when I turn it back on...its still remains...anyways was able to locate a shop...will be heading there tomorrow. Thank you...
  #4 (permalink)
Old 11-11-2009, 07:50 PM
That mean that the problem is consistent. A common problem on your Maxima is the ABS wheel sensor or sometimes is just low brake fluid. Please let us know your findings.
  #5 (permalink)
Old 11-12-2009, 06:03 AM
Mycabert's Avatar
Newbie
Thank you...have an appointment this afternoon. Will let you know of findings. Thank you. Have a good one!
  #6 (permalink)
Old 11-16-2009, 06:02 AM
Mycabert's Avatar
Newbie
Well, Iw ent to the shop and we found the problem...it was the right rear sensor. It said right rear sensor open....So i purchased the original sensor from a nissan dealer and once placed and a reset was done, the ABS light was gone. Thank you for your inputs on this matter. Much appreciated.
Trackbacks are On
Pingbacks are On
Refbacks are On
THINGS YOU CAN DO ALSO ON NISSANHELP.COM NISSANHELP.COM STORE
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.3.0
