All Models, All Years 370Z Coupe 2010 370Z Roadster 2010 Altima Sedan 2010 Altima Coupe 2010 Altima Hybrid 2010 Armada Cube 2010 Frontier Crew 2010 Frontier King GT-R 2010 Maxima Murano 2010 Pathfinder Quest 2010 Sentra Sentra SE-R Rogue Titan Crew Titan King 2010 Xterra Versa
Do-It-Yourself Cost Estimator Maintenance Owners Manuals Recalls/Campaigns Service Bulletins Service Manuals MyNissan
Auto Parts Car Cover Clear Cargo Mats Clear Mats Hexomats Hexomat Cargo Sunshades
Go Back   Nissanhelp.com > Models > Maxima
  #1 (permalink)
Old 10-31-2009, 01:36 PM
~R.Dawg's Avatar
Newbie
2000 Maxima SE
Default Automatic trans stuck in park
I have a 2000 Maxima with automatic trans. When we start it up and try to shift out of park, it is hard to push the button in. When it started doing this, we were able to push the shifter all the way to the front hold then push the button. Now it is a bear, wiggle, pray, ect.
Any ideas???
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
  #2 (permalink)
Old 10-31-2009, 08:07 PM
sergey85's Avatar
have you had it checked out? how many miles? how is the transmission fluid looking?
2002 Maxima GLE Silver on Black
| Berk Intake w/AEM Dryflow | Clear Sidemarker Lights w/PIAA L.E.D|PIAA L.E.D Courtesy and Licence Plate Lights|PIAA White Fogs |Fibre Customs EyeLids | 5% Limo Tint | Brembo Blanks and Hawk HPS Pads |Ebay FSTB|CATTMAN RSB| NWP VIAS Block plate | OEM Spoiler | 07 350 z rims on 235/45/18 Goodyear Eagle GT tires|
in training
SHOW YOUR SUPPORT: Subscribe or Donate
  #3 (permalink)
Old 10-31-2009, 08:23 PM
~R.Dawg's Avatar
Newbie
2000 Maxima SE
The fluid was changed about about 75000. I noticed there is a clicking in the steering column. It has 110,000 miles. I haven't had it checked out yet. I thought I would ask here first.
  #4 (permalink)
Old 11-01-2009, 05:27 AM
~R.Dawg's Avatar
Newbie
2000 Maxima SE
It really sounds and feels as if it is the button itself. Once it is depressed it will work for a few parkings then it will stick again. This button is tied into the steering column. I can hear a clicking in the column. probuly the locking of the steering wheel.
  #5 (permalink)
Old 11-02-2009, 05:30 AM
tech22's Avatar
2005 Frontier Crew Cab
05 nissan frontier
Check the trans lockout switch located down by the brake lite switch.Its called the neutral safety switch.When you press on the brake you should hear/feel a click in the shifter.
  #6 (permalink)
Old 11-02-2009, 09:29 AM
I agree with tech22 but I a couple of question:
When you press the brake pedal to release the shifter from parking, do you hear a clicking noise around the shifter are?
Does the stop light comes ON every time you press the brake pedal?? (Please check several times)
NEW - MPG Estimates - Share your MPG
Nissan OBD-II Trouble Codes Chart
Show your support to our forums: Subscribe or Donate
  #7 (permalink)
Old 11-02-2009, 09:28 PM
~R.Dawg's Avatar
Newbie
2000 Maxima SE
Yes there is a click everytime I press the brake. What if soda was spilled around there? When I pryed up the rubber around the console it was sticky.
  #8 (permalink)
Old 11-02-2009, 09:52 PM
The soda can cause the shifter solenoid to stick, very common problem. You have to used lots of electrical parts cleaner to get it off, but sometimes you have to replaced the solenoid to fix it.
  #9 (permalink)
Old 11-02-2009, 09:55 PM
Here is the diagram of the shifter to help you locate the solenoid
  #10 (permalink)
Old 11-03-2009, 05:29 AM
~R.Dawg's Avatar
Newbie
2000 Maxima SE
I took the shifter knob off but that is all I could get. Can you give me a summary of how I get to the solenoid? Thanks
  #11 (permalink)
Old 11-05-2009, 01:22 PM
Maxdom's Avatar
Newbie
You also might want to make sure that the brake lights come on when you press the brake pedal, as NissanTech suggested above, just to rule out a brake light switch problem. (I had that happen to me)
Trackbacks are On
Pingbacks are On
Refbacks are On
THINGS YOU CAN DO ALSO ON NISSANHELP.COM NISSANHELP.COM STORE
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.3.0
