no low beam head light Forums > > no low beam head light no low beam head light
Old 07-13-2009, 06:59 AM
lmf
Default no low beam head light
Help, I have 2001 SE Max A/T. The low beam on the drive side does not work. No it is not the bulb (tested this) and it is not a fuse(tested this as well). The high beam works.
The pass side works (both low and high beam)
I also concluded that no power is reaching the connector.
The wires look good, and do not appear to be broken
Any sugguestions as what the fix could be? Welcome any sugg.
Thanks in Advance
Old 07-13-2009, 10:27 AM
If you are in Canada, I'm assuming you have a DTRL, if that is the case the low beam is controlled directly from the day time control unit. First check for ground at pin #14 of the control unit. The unit receives the signal from the switch at that pin. If there is ground, then check for voltage at pin #11 of the control unit. If there is no voltage at pin #11 but there is ground at pin #14 then the problem is most likely the DTRL control unit.
no low beam head light-figure4-gif   no low beam head light-figure5-gif   no low beam head light-figure6-gif
Old 07-13-2009, 01:27 PM
lmf
thanks for your help.... can u tell me were on the car is the DTRL control unit
Old 07-13-2009, 01:46 PM
streamcast streamcast is offline
1997 Altima
1995 Sentra
1995 Nissan sentra
Next to the battery, definitely the DTRL if you have daytime running lights. In Canada this module is not cheap, range 3-600$
Old 07-13-2009, 03:53 PM
lmf
thanks for your help. cannot find the DTRL mod by end of week will take to mech
thanks again
Old 07-14-2009, 01:44 PM
lmf
for future reference on the 2001's it is a white box attached to the body on the passenger side of the car, right behind the head light.
Price from dealer is $250.00. not that bad
Old 07-16-2009, 02:21 PM
lmf
Thanks NissanTech
I found the dtrl unit and replaced it. The dealer sold me a rebuilt unit for less than $100.00 with a warranty. He told me that he has never had one of these rebuilt units come back.
Could have not done the repair with out your help
Old 09-28-2009, 12:40 PM
bl7734 bl7734 is offline
Default Was is hard to replace?
Originally Posted by lmf View Post
Thanks NissanTech
I also have an 01 (GLE) was the DRL module by the battery or on the passenger side? Is it hard to reach/get at for replacement?
Old 09-28-2009, 12:41 PM
If possible please post photos.
Old 09-28-2009, 05:18 PM
lmf
Smile
White box behind headlight on passenger side of car. Not very difficult to do. Most difficult part was unhooking wire connections. (plugs).
Should take less than 5mins.
Old 11-13-2009, 11:38 AM
slidewayzm5
NissanTech...
I also have a 2001 Maxima SE (5spd) with a drivers side low beam light problem. It is not the bulb, and the safety mechanic said it wasn't the fuse either.
I removed all 3 connectors to the DTRL... then I checked the ground @ pin 14 (no ground), and voltage @ pin 11 (no voltage).
What does this mean? And what do I do in order to fix the problem?
Thanks!
Old 11-13-2009, 02:31 PM
slidewayzm5
I also tested the connector @ the lights - it has voltage, but NO ground... Thoughts? Please help - I need to safety the car asap!
Old 11-15-2009, 11:28 AM
lmf
It is mostly likely you dtrl unit. Should solve the problem once it is replaced
Old 11-16-2009, 10:47 AM
lmf
let us no once the repair is done
Old 11-16-2009, 12:49 PM
slidewayzm5
Having a hell of a time tracking down a DRL module in western Canada. Every wrecker out here goes O.o when you mention a 'maxima'
2000 or 2001 should fit.. and also Infiniti I30's of those 2 years.. yet no one has em.
beam, head, light, low
