Brake pedal firm when engine not running..goes to floor when running! Forums > > Brake pedal firm when engine not running..goes to floor when running! Brake pedal firm when engine not running..goes to floor when running!
Frontier Nissan Frontier/HB/Truck Discussion Forum
Old 04-14-2010, 12:09 PM
ronald467
Default Brake pedal firm when engine not running..goes to floor when running!
I have a nice firm brake pedal when the car is not running, as soon as I start the engine, the pedal goes almost to floor.
So I ruled out the master cylinder, since I just replaced it last week. I bled the brakes and the master cylinder at least 10 times.
The diagnostic check on the brake booster appears normal, except that when I start the engine with my foot on the brake, the pedal goes almost to the floor with a very mushy pedal.
Can somebody shed some light on this problem? The brake booster holds vacuum just fine so again I am lost. What could this problem be?
Anyone have any ideas?
99 Nissan Frontier 4x4 (ABS bypassed) V6 - New Calipers, New pads, new brake lines, factory rebuilt master cylinder.
Old 05-27-2010, 04:13 PM
metal_clutch
It's either a vacuum leak or your booster is leaking. Booster runs off vacuum. Booster run brake systems usually require replacing the booster and master cylinder at the same time. What typically happens is the master cylinder starts leaking and consequently leaks brake fluid into the booster. This destroys the seals within the booster and you loose pressure. In a slight leak, the booster pressure can be built up when the engine is off, because it's not pulling vacuum. Once you crank it up, your pedal hits the floor.
Either that or you still have air in the brake system. Do you have to purge an ABS system on these vehicles when bleeding the brakes?
Old 05-27-2010, 05:30 PM
ronald467
I replaced everything with a good used system and re-bled the brake system another 10 times and I now have brakes, I really don't know what the problem was, probably a little bit of all of the above. At least now I have brakes, and Mr. Whizard fixed my entire dash cluster problem so I am a happy camper now.
Old 05-28-2010, 12:05 PM
jlg2002's Avatar
jlg2002 jlg2002 is offline
2005 Frontier King Cab
2005 Frontier LE King Cab
Where the Heck did you derive this off the cuff booster comment from? I've been a ASE certified brake technician and this has never been the case with automotive vacuum assist systems
Old 05-28-2010, 12:56 PM
jacko48j jacko48j is offline
2003 350Z
03,09 350Z and G37x
Good question jlg. Some of the "help" that shows up here from time to time has me asking the same question. There is alot of good help here but sometimes------not. Thankfully it is not very often.
Old 05-31-2010, 03:21 AM
tech22's Avatar
tech22 tech22 is offline
2005 Frontier Crew Cab Frontier Crew Cab
05 nissan frontier
Does this mean that when i'am in park with the engine running the block rotates around the crankshaft? I can't wait to hear how an a/c system works...
Old 07-25-2019, 11:59 AM
TomL77 TomL77 is offline
2010 Frontier Crew Cab
2014 Rogue
2004 Frontier XE
Did you ever solve this problem. I am having the same problem with my 2010 Frontier. Just replaced the MC, pads and all hoses. Still having the same problem. I had a 2004 Frontier and the brakes were outstanding. I would expect the same on this newer one. Truck has 102K miles on it. I purchased it with 90K. It stops OK but peddle is squashy.
Old 07-28-2019, 08:12 AM
Did you bench bleed the master cylinder before bleeding the system? If you did..good. If you bled your brakes the ol' "bleed from the furthest brake up" method, that may be the problem. Nissan has several different brake bleeding procedures depending on the year and model. Always refer to the factory service manual procedure before you start bleeding the brakes. If you don't have an FSM, NICO Club's website has free online manuals available for use.
Old 07-28-2019, 10:32 AM
2014 Rogue
2004 Frontier XE
Thanks for the reply. Yes I did bench blead the MC. After replacing the hoses I did blead the system. I just blead each one as I replaced the hoses. Both front first then both rear. I did not refer to the manual which I do have. I will investigate. One thing that I did noticed while observing the MC and boaster while a friend pressed hard on the peddle with engine running is that the MC moves slightly forward with the surface of the boaster. Could it be that Nissan is making the boasters from thinner material. My wife has a 1014 Rogue and it has a firm peddle always.
Old 08-03-2019, 08:56 PM
Are you sure it's not the firewall that's flexing? Just a thought. I remember working on an old Datsun 720 that had a weak firewall due to corrosion and the brake booster would move forward when you pushed the brake pedal down with force. Otherwise, Gen 1 Frontiers typically have solid-feeling brakes when they are properly adjusted. There are a number of people that complain that they grab too hard or lock-up.
Old 04-22-2020, 07:15 AM
WMitchSr WMitchSr is offline
2014 Murano
I realize this is a Frontier forum, but I am having the same problem on 2004 Xterra and didn't want to reinvent the wheel. I purchased this vehicle about a month ago from a private owner. The pads and shoes still have about half their life on them. The pedal wasn't spongy, but when the brakes engaged, the pedal was like an inch from the floor to start. Tried bleeding as per FSM and broke a rear bleeder fitting off so figured it wouldn't hurt to replace rear wheel cylinders. Got everything bled again and no change in pedal. Fluid was pretty dark, so next I changed the MC, bench bled and re bled the whole system again as per FSM, including cracking the lines at the ABS actuator. Still have the same pedal as what I started with. I did the booster test as per FSM and booster checks out good. I also adjusted rear brakes with minimal gain.
This is what is in the FSM:
Bleed air in the following order.
– Left rear brake
– Right rear brake
– Left front brake
– Right front brake
– ABS actuator/VDS
Is cracking the ABS actuator lines at the module the correct way to bleed it or should I buy an OBDII device that supports this procedure.
After all this work, the pedal is no better and no worse. Thoroughly frustrated at this point. Any help would be greatly appreciated.
Old 04-23-2020, 05:30 AM
Cusser's Avatar
Cusser Cusser is offline
2004 Frontier King Cab
1998 Pathfinder
1998 Frontier
WMitchSr - this vehicle is new-to-you. I would check the brake pushrod length/adjustment as per factory service manual. You have no idea what was done on this before you got it.
Old 04-27-2020, 05:51 PM
2014 Murano
That is not the problem. As stated in the beginning of this thread, the brake pedal is firm and within limits when the car is not running. Straight to the floor when it is started and running. If I would adjust the pushrod to where it would be in spec while running, it would push it way out of spec when not. Is there anyone that has used an OBDII device to cycle the ABS actuator? I would buy one if I knew for sure this would help the problem.
brake, engine, firm, floor, pedal, running, runninggoes
